Clutch movement
jimmy1979
20+ Year Member
Fort Lewis, WA
If I look into the opening on the bottom of my transmission(91 ext cab, 4x4, 5 speed, 4.0) while someone is pushing the clutch pedal, I should be able to see some movement in there right?
Had to remove the master and bench bleed it, then did the gravity feed with everything installed. Now I can see things moving.
Is there supposed to be a cover or plug on that inspection hole? It seems kinda odd that the clutch would be left open like that.
