runs rough
houmic48
10+ Year Member
I have a problem. My 85 bronco 2 2.8l carbonated runs rough. It doesn't seem to matter whether it is cold or warm. What fixes it is when I floor the gas for a couple of seconds but then it will start again a couple of minutes later. I have busted the inside of my catalytic converter and emptied it all out already so I am pretty sure that it is not the problem. I am thinking either the muffler is clogged or what I was wondering is if it could be the erg valve? It also smokes alot (black smoke) when I floor it when it acts up. I just want some other opinions on it since it is -20 outside and I want to make sure I am in the right direction before I work on it. Also the air pump does not work and the metal lines for the air pump are rusted through and busted (was like that when I bought it). thanks for any help
I'd be looking at the choke on the carb.. The black smoke is from too much fuel. If the choke isn't pulling off as it should it would run rough..
Big Jim
A good carb. cleaning and rebuild probably would hurt either.
