I have a question about the distributors used with the duraspark ignition systems. I have two of them and they are quite different.
One looks like the one they recommend to use in the tech article. It has an adapter and a large cap with the exposed terminals. It also has a large vacuum port.
The other is a one piece cap that is the same size as the stock one. This has a female type terminal setup on the top as well as a much smaller vacuum port.
Which one is better?
