- May 28, 2008
I've been having issues with my new truck lately. At first, it was sluggish, coming from a 4.0 explorer with a 5 speed, I was expecting it. Then I started realizing that, THIS AIN'T RIGHT!
I replaced plugs (bosch super+platinum) and wires, did an oil change (castrol 10W-30 GTX, Fram SuperGuard filter). I was happy then with how much power I unlocked...
Then, on Sunday, I went to a July 4th festival, which I had to climb about 1000' in 27 miles. On every hill I came to I had to drop to 4th... then 3rd... got up to the top and truck was fine again. Next hill, same shit. So when I got home I slot cut the airbox, put a fuel filter in it, and also a 4 liter radiator I had laying around.
Now it seems to be worse... when I shift to 2nd or 3rd gear and give it gas, it acts like its being flooded or not getting gas at all. When I give it gas, it chugs down and almost dies unless I let up. Also, now it is popping on the passenger side, almost like a backfire, but smaller.
Figured you guys would want codes...
CM = 89 - 86
KOEO = 1 - 41
KOER = 1 - 41 - 77 - 74
By what I get out of it...
CM 86 2.3L or 2.9L Truck - A4LD 3/4 shift solenoid - Transmissions
(M) 1.9L MFI - System has corrected lean condition - Fuel control
CM 89 A4LD - Converter Clutch Override solenoid - Transmissions
AXOD Torque Converter Control solenoid circuit - Transmissions
Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
KOEO 11 System checks OK
(I'm guessing the 1 is supposed to be 11)
KOEO 41 (R) System lean - Fuel control
(M) System was lean for 15 seconds or more (no HO2S switching -
Fuel control
KOER 11 System checks OK
KOER 41 (R) System lean - Fuel control
Fuel control
KOER 74 Was brake depressed after engine ID was received ?
Brake On Off (BOO) signal open or short to ground - BOO
KOER 77 System did not receive "goose" test - see TESTS
CM = 89 - 86
KOEO = 1 - 41
Fuel control
Fuel control
