notched cross pins are $HIT, they suck and are known to break. Use your stock cross pin, and just shave a little off the ring gear, you dont have to remove much. Install your ring gear, and you will see exactly how little youll need to remove to be able to slide it in. I used a 4.5 " grinder
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
