- Mar 31, 2010
- Kearny, NJ
- 2.9 V6
- Total Lift
- 1"
- Tire Size
- 31x10.5R15
I bought a Mazda tranny out of a '96 Ranger 4.0 to replace my destroyed FM146. I will be doing this swap soon, but I want to make sure I'm not forgetting anything so that this will go smoothly.
I need:
- the transmission (M5OD)
- 4.0L flywheel and clutch kit
- 4.0L manual transmission starter
- slave cylinder (I assume same year as the tranny? or does it not matter...)
- 16AWG wire
- 4.0L shift boot
- 4.0L shifter (the one from my FM146 won't fit?)
- 4.0L floor tin
- perhaps a new driveshaft (front or rear?)
The install:
I believe this to be the process, but please let me know if there is more involved here.
1) Disconnect battery.
2) Remove shifter knobs & shifters
3) Undo all wiring to transmission & transfer case
4) Drain transmission & transfer case
5) Remove driveshafts
6) Remove starter & starter plate
7) Support transmission
8) Remove crossmember.
9) Unbolt transmission from engine
10) Lower transmission/t-case.
11) Disconnect tranny from t-case
12) Install in reverse.
Am I on the right track? This will be my first transmission removal/installation. The second will follow on the Jeep with a V8 swap, but that's much later. This comes first.
I need:
- 16AWG wire
- 4.0L shift boot
- 4.0L floor tin
The install:
