AgPete139
09/2014 OTOTM Winner
⭐Supporting Member
- Aug 12, 2007
- Houston, TX
- 4.0 V6
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
Very unusual driving shudders & idle
Hey guys,
I've had a problem with my 1992 5.0L Mustang GT for the past couple months... (please read)
I've read quite a few threads (& I hate reading reposts), but I'm stumped.
Recent maintenance:
Other notes:
Please someone help. I am getting tired of this!
Thanks in advance!
Pete
Hey guys,
- At idle 800 rpm, my engine suddenly drops to 200 rpm every 6 seconds.
- When I am cruising in 5th gear @ 2000 rpm @ 70 mph, the entire car randomly shakes and shudders violently (the entire car wants to lurch forward/stop/fwd/stop). Hard to predict. It happens in every gear, & is RPM related).
- Hard acceleration past 2000+ rpm makes it barely noticeable.
- Sometimes I am forced to bog the engine just to avoid jerking.
Recent maintenance:
- Cleaned IAC / TBV solenoid.
- Expanded & contracted the 10-pins Salt & Pepper Shaker connectors
- Expanded & contracted the 3-pins EGR connector
- Cleaned MAF
- Cleaned Throttle Body
- Set Throttle Position (TPS) to 0.91V (it exceeds 2.7V @ WOT)
- Reset Base Idle
- New spark plugs gapped @ 0.054"
- Flushed coolant system / radiator / heating
- Replaced harmonic balancer/dampener/damper (shimmy, rubber worn, 1 month ago)
- New heater core (leaking, 4 months ago)
- Fuel filter (clogged, 6 months ago)
- Oil change (1 month ago)
- New starter (bad, 2 months ago)
Other notes:
- I do not have fuel pressure gauge installed, and I am unsure how to test the EGR.
- A small amount of moisture exits my tailpipes, but that's normal.
- My #2 cylinder spark plug was slightly more whiter/gray than the others, but I have since regapped. There is a small amount of rust on that part of the fuel rail, but nothing even major. (It's a Texas car.)
- I did not notice a change in idle with propane in the engine bay (same theory as using carb cleaner to test for seal or vacuum leaks).
Pete
