Body Mounts On 94 Explorer!
jake122288
good old pleasantville, Iowa
well i was removing the body bolts to install my BL kit...and on the farthest two back (at the back hatch) i ended up with this
i looked under the truck where the bushings are and unlike the side ones (front floorboad and behind rear seats...i cant really see a bracket or anything that would connect it. to me it looks just like the bushings go on and the bolt goes through the body through the bushings and through the frame and tighten on the square nut thinga ma jig (unsure what to call it) Is that square nut part of the bushings or is it part of an actually bracket that attaches to the frame (similar to the other ones i mention. I just need to know what i need to buy or get at a JY so i can get this finished thanks for any help
i dont understand what you need. do you need a bolt or the factory body bushings? i hope you left the stock bushing in there and put the lift block on top of them
ok i see there is two pieces of what i would call the body bushing/mount. the bolts are the only thing replaces i havent gotta as far as putting the blocks in and i have bolts that cae with the BL kit... that square nut thing on teh bottom beneath the frame? fell through whe the original bolt broke. so is there a special mount/bracket like the other (like the body to frame mounts by the front floorboard) or is that just part of the bushings? bolt wise im good...but there is something i need and im not sure what it is which is why im asking did this make it any clearer...i can get pics tomorrow morning and post them if needed of the actual underside
here is the pics of my ream most body mounts? where can i get these mounts from?
passenger side rear most mount underside
drivers rear most underside
and do these come in a set with the upper and lower ones i obviously need two new body mount bushings...does anyone know where i can get these?
ok i went ahead and pulled out the upper part (between frame and body) of the rear most body mount (pass side) now that meatal ring that sits ontop of the bushing? i think i need that along with everything (unsure what there all is) for the lower part (the part that is actually benieath the frame)
these are pics of the upper body mount? what does it look like i need (i would like to replace all hardware including that metal ring thats above the rubber) and i also need to know what is all with the lower part (beneath the frame)
with this last pic im unsure if there is supposed to be a metal sleeve or something in there that the bolt goes through or what...any and all help is greatly appreciated thanks
ok thats what i thought go to lmctruck.com and order the body mount kit for your year explorer its a good time to get them replaced. i need to order them for my ranger but im waiting for extra cash to come my way.
Here is a link to the mounts but its not a replacement kit its individually.
CLICK ME
CLICK ME
pk but now another question...that u may answer or i'll have to call LMCtruck.com but.... will those be exact stock direct replacement...with the square nut on the bottom and sleeves and everything (minus the bolts i have those)
i think so but you might want to call them. i cant find the whole set like they have for the ranger i would suggest buying a whole set so its the safest possible
that looks like everything you need but call them and make sure
no problem do you want to order mine for the ranger while your at it ??? lol
haha its cool man i know how you feel
how about we spin this around and u get me the ones for my explorer hahahaha make it my birthday present!!!! (god that would be weird buying a birthday present for someone turning 21 that you dont even know...and it not being shots at the bar? LOL!!!!! :yahoo:
