4.0 swap into 88 ranger
Boggin
so i got a few questions that im still unsure of after reading through the tech library
1]what years did the ranger get the 4.0
2]can i use the stock harness and plug and play into the 4.0
3]use stock motor mounts?
4]will i need the 4.0 rad
5]are the 2.9 and 4.0s bellhousing pattern the same
6]will any custom fab work or modification to anything have to be done
7]im 14 dont have a garage like some of you guys got i just got a shed with only about 200bucks worth of tools, can it still be done?
that all i can think of for now
thanks guys
1]what years did the ranger/explorer get the 4.0? - 90-2001ish, you'll want 95 or older - OBD1.
2]can i use the stock harness and plug and play into the 4.0? - On an '88, no, there will be some splicing
3]use stock motor mounts? Yes. They did change them tho, however, I don't know what year...
4]will i need the 4.0 rad? Yes
5]are the 2.9 and 4.0s bellhousing pattern the same? Yes
6]will any custom fab work or modification to anything have to be done? No
7]im 14 dont have a garage like some of you guys got i just got a shed with only about 200bucks worth of tools, can it still be done? Anything can be done fool
All good answers. Only thing I'll add is 94 or older for OBD-1.
ok so what will need to be changed cause i dont want to do it if i got to be gettin pissed off with it day after day after day lol
Oh was it 95 they switched? I thought it was 96...
I don't monkey around with these silly newer vehicles..:D
95's kind of a changeover year, with the OBD-2 computer but uses some OBD-1 components for diagnostics. I really don't understand how it's all wired on a '95, but the '95 2nd gen Explorer I looked at for sale a month or so ago had an EEC-IV test port under the hood.
Odd...:icon_confused:
It all gets confusing after that..
where is the computer located on the ranger?
Behind the passenger side kick panel
I gotta agree with Black BII...anything can be done. I was like you (except 17 and I have a welder) when I did my SBC swap in to my 86. Just keep at it and never let a screw up or set back get you of track of the final goal.
Good luck.
Good luck.
dont have to worry about that:icon_thumby:
when i was doing the engine on my b2 i would always screw up, andmy dad and all my friends would say that she would never be going again, but i kept at it and now she runs perfect with 270k on her:headbang:
