- Aug 16, 2007
- Age
- 39
- Oregon
but then why would it only happen when in 4wd?
Good question, but once a minute seems far too slow for that to be the problem. Driveline windup occurs normally during turns.
The lean misfire problem is an interesting one....though I'd submit the current situation sounds more like a rich misfire (in which case it would be accompanied by a puff of black smoke visible to everyone outside the vehicle).
By any chance, is the check engine light on? Does it work with the key on, engine off (should be lit).
So i didnt notice the slipping sensation for a while, but it came back ever so slightly on saturday while doing some light wheelin. i just drained the T-case to look at the chain and the tension seemed fine (i could move it about 1/4 inch when poking with a screwdriver).
