clutch wiring please help
red_ranger93
ontario
i need to know what wire i can just put together so i dont have to push the clutch in to start the motor
Behind the clutch pedal, up towards the top, there should be a safety button that controls that function. Every time you push down the pedal far enough, the switch "allows" power to the starter.I suppose if you figured out a way to keep the switch ON, you'd be in business.
If you do figure out a route for that, BE CAREFUL!!!! The starter is MORE than strong enough to power the truck forward if the pedal is not depressed.
That's why that switch is there. May hit the car or object parked in front of you, or it might send you into oncoming traffic, thats how my great-aunt died.
do u know the wiring scheme so i can hook it up to the original ranger one
1. No, I don't know the wiring for that switch
2. Hook it up to the original ranger? I don't follow.
If you don't want to push in the clutch to start it, just tape the switch down so that it's always "ON".
I just know this from my '95 escort I used to own, should be the same......maybe
Should be a Red or Pink slightly thicker wire going in and out of the above mentioned switch. Just bypass the switch by connecting the two Red/Pink wires and that should do it.
