- Apr 3, 2021
- Phoenix, AZ
I did a complete front disc brake overhaul this weekend. I have done this procedure before including bleeding the brakes.
I could not get any brake pedal pressure after multiple bleeding procedures.
I replaced the master cylinder yesterday too. And still zero brake pedal pressure. All the way to the floor.
I turned one of the caliper banjo bolts a couple more turns. Checked the connections again for leaks.
I use one-man speed bleeders. This morning I discovered the left front speed bleeder is slowly discharging fluid droplets in the closed valve position.
I also saw it pushing out a couple small air bubbles. So it looks like this speed bleeder is partially stuck in the open position.
The other speed bleeders are ok .
I also checked to make sure I didn't switch the caliper positions. I included a pic.
Is that caliper installed correctly with the bleeder in the right position ?
Is this one bad speed bleeder enough to cause a completely slack brake pedal?
