Refurb, rebuild, or used?
The 2.5 Lima is a pretty robust and simple engine. If you can get the replacement refurbished and built, you should be good for a long time. There is a reason that engine got used in a lot of commercial equipment.
$1,000 seems steep but it has been more than 14 years since I replaced the engine in the 1998 that I had for $300 at about the same number of miles. So, prices are going to go up, whether I/we like it or not.
If I use the junkyard search engine, blocks go as low as $250, but that's just with a grade, no mileage, and they generally aren't pulled, much less shipped. It is steep, but "bring a trailer" rust heaps are being listed at 2-3K!!!
I am going to check the big city of Lincoln this Friday on the off chance they have a 2.5 Lima. What's hilarious, is there are three things I really want:
Extended cab
Manual transmission
2.5
My coworker has his "Red Rocket" 2000 Ranger with....extended cab, stick shift, 2.5. Only 190K miles.
He won't sell :(
In those years I would probably open up to the Duratec 2.3, it jumps almost 10 horsepower and like 4mpg from what most say... it's not a bad engine, definitely different and more complicated but also reliable... but that gets into finding one that's affordable again...
The mpg is probably all from losing the cast iron blockand head and going to aluminum. LOL
If I tried to use a different engine (I'm a noob remember), don't I have to switch out computers, sensors, etc?
PS; my daughter's 2003 focus uses that engine lol...thing zips around pretty good.
Good yard, they usually have more older stuff than either Omaha yard. :icon_thumby:
Oh, swapping engines would be a disaster (doable, but they're integrated to things like the body module, have chip key and such...), it seemed like you were daydreaming about finding a different Ranger...
My brothers escape has the 2.5L version of it, it's decent to work on at least in that... When I was looking for a new daily driver I wanted some boxes checked, I'd considered the Duratec but wanted I beam front suspension and ended up finding a good deal on my '97... kinda wanted a '92 but OBD II got me into the 3rd gen instead... I mean when you find a fixable '97 with 142k on it for $450 that just needed a suspension beam, rear window, drivers door and some tinkering it's hard to pass up, I think I had $700 in it by the time it was driving...
I see. I am open to a 94-97 if it's checking my boxes, but still hard to find at a price that's realistic relative to just fixing mine.
LINK
May have an engine. It'll end up at the machine shop (taxes, shipping, etc) for a little over $1,300. It's a lot, but it's the market. It's from Rosamond, CA so at least it hasn't been sitting in a swamp somewhere. 135k miles on it, we'll see.
I was curious, if you zoom in above the rear freeze plug (is that a second plug?) you see the name of the parts company (tapatio) on whatever that is, some sort of plug.
That is a telltale, if they offer a warranty on the engine the center will melt out if you overheat it so they can refuse warranty... looks like they just put it on.
That's new to me. Well, I'm pumped. My heart wasn't really into just buying a whole new truck. I like that I can just keep working on this one. I know a lot of you guys have multiples, and maybe that's in my future, but for now it's just the one.
So I've given up on truck shopping. Absolutely criminal, the market right now (I know it was worse a few years ago). So I'm going to, at some point, need a new engine as my little 2.5 lima won't last forever. Well, probably not.
So I want to start shopping and preparing, and I wanted your opinion. What's the better option? A full overhaul/rebuild with a machine shop getting after it, a low mileage used engine, a refurb (if so, who?).
I'm not eager to spend money for no reason, but no matter how much I spend it'll be cheaper that buying a truck that's going to need work anyway. And, well I want to keep this one. A lot of emotional value to it.
As always, any help appreciated.
We sell engines for industrial and marine use at work so we use those as of the last few years for good measure...
If it's really that low of miles I would be tempted to get one of THESE to see if the cylinders are sealed real good and if so just change some gaskets (front and rear crank seals, cam seal, oil pump seal, oil pan gasket and valve cover gasket) and just run it... Like I mentioned above I got my '97 2.3L at 142k in 2019 and I've put 100k on it since then and the only serious issues I'm having with it are the valve cover gasket at the moment... it doesn't lose enough oil to add any between changes but it's a gross greasy mess...
If you do get a leakdown tester like that they're pretty simple to use, kinda like a compression tester but you don't need to crank it over. Basically you put it on top dead center for each cylinder one at a time, thread it into a spark plug hole and pressurize it with an air compressor. I like the cheap ones less than the Snap On one we have at work since they only use like 15psi instead of 100psi but they do work... It'll tell you where the air is leaking be it valve or ring related and show whether it is in good shape or not
I would pay someody else to do it. I like the assurance. If there's any problems, then it's on them. Either way, it's a worthwhile endeavor.
I think that if my own engine were to blow today, I would get it replaced. I would want the best engine money could buy too, something maybe even blueprinted, magnafluxed, bored, polished, dynotuned, maybe even a special cam or lifters.
A Ford Ranger may not be a race car, but it is a very special breed. It's made to e as light in weight as possible to increase its payload, pull like an ox, get good mileage along the way.
Mine's even got an aluminum hood and fiberglass fenders: features only reserved for sports cars years ago. Granted, maybe those small changes just save fifty pounds, but they make a difference over the life of a truck
Event Coverage
TRS Merch
