New to me, 2003 Ranger has no turn signals or brake lights
tompands
ASE Certified Tech
Rockledge
FL - USA
Vehicle
Drive
Been working on this truck for 3 days doing little odd's and end stuff. Just realized i have no brake lights or turn signals, parking lights work. fuses are good. Whats the secret??? I know you know>>>>>
no flashers either
maybe a ground?
i went through no parking lights and no cluster lights last week. turned out a pin had gotten pushed out of the plug where it goes into the headlight switch. what a pain that was to find since i wasn't looking for a messed up plug to a switch. i found it accidentally because the wire bundle felt weird when i was pushing it together.
bulbs are new
Front... rear or both for turn and hazards?
ALL bulbs are new. The weird thing is when the truck is running and I turn on right side or left side turn signals, they work in the front as they should. But nothing in the rear. They don't blink fast, like a bulb is out, they blink normally. So I'm losing signal to the rear somewhere. I'm thinking turn signal switch. What do you think??? AND, when I turn hazards on The front work and the faintest glow at rear lights can be seen.
Was gonna suggest grounds, but if the parking lights work...
