My 2011 Ranger has been having rough starting and the odd misfire code. I just hooked up a pressure gauge and when turning the key on I got little pressure but when the truck starts it jumps up to 65psi.
Also, if I cycle the key the fuel pressure goes up about 10psi with each key cycle. This explains why the truck starts rough sometimes but runs perfectly after. I just want to confirm that it is the fuel pump before I spend the money on a new one and an entire day changing it. Anything else it could be? My battery is good at 12.4v (good not great). Truck has a new OEM fuel pump relay as well (not sure if that could cause the issue?) Thanks!
