- Nov 25, 2024
- Age
- 73
- 2.3 (4 Cylinder)
- My credo
- Semper Paradus
Hi All,
I have a 1987 2.3L EFI 2wd Ranger with manual trans that will not run. It has low mileage and good compression.
It had been setting for years. I have already done a number of things to try and get it running.
Below is a list of things completed on the Ranger.
Removed and cleaned the Fuel Tank.
Replaced both Fuel Pumps. (Fuel Pressure at 40psi).
Replaced Fuel Injectors. (Checked with NOID Light).
Replaced Fuel Pressure Regulator.
Replaced Fuel Relay.
Replaced Computer.
Replaced Timing Belt.
Replaced Distributer Cap.
Replaced Plugs and Plug Wires.
The truck seems to still have a fuel problem. If I pump the throttle pedal vigorously, the engine will try to start for a second, but not completely catch. If I spray fuel into the intake it will start and run for two or three seconds then die. I have checked for fuel flow while cranking the engine over with the injectors removed and I get fuel spray from the injectors. The NOID light test works correctly. The engine timing is set correctly. When the engine does fire it runs smoothly at high RPM for 2 or 3 seconds then dies.
Any suggestions would be greatly appreciated. Thanks!
Replaced Computer.
