holyford86
Some guy with a problem
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
Has anyone successfully gotten more power out of the power steering on ttb trucks? I've been doing a bit of research on it and haven't seen a ton.
Right now I've got a good low mileage used factory steering gear installed, after having terrible luck with reman units leaking or having tons of play in either the input shaft or sector shaft (or both). A large cooler (it's a trans cooler from an auto truck) and one of the unicorn Cardone conversion P pumps. I feel it's a pressure related issue, adding rpm doesn't seem to increase assist any measurable amount, unless I'm thinking about it all wrong.
I've read about pressure and flow mods that can be done to the pumps but am hesitant to do them and damage the only unit I have.
I have no issue swapping to a different steering gear but research tells me finding a pitman arm to work with my steering may be difficult. I've seen some people adding a small hydro assist cylinder as well, but not sure if it'll be worth the effort.
Anyone have any other ideas or experience?
