Hi Guys,
I'm just losing my mind. Here is a short video from my engine "idling". Current state is:
The current situation is clearly visible on the video I posted. By the smell it is still running extra rich, but I'm sure no injectors are leaking because fuel pressure is steady at around 38 psi. Last thing that I have in mind is to check ECT reading at the ECM connector - maybe there are some damaged wires. Other than that I'm completely lost and out of ideas. Please, point me in some direction guys, because I dumped a ton of money into this rig, especially that I live in Poland and each single part I buy I have to import from US paying extra shipping + duties + taxes. I don't regret it yet because its a cool looking car and I always wanted to build a dropped patina truck, but I don't know what else to do/check/replace before I tear up the engine which is last resort really.
Best regards,
Jerry.
- All sensors new (IAC, ECT, ACT, TPS, MAF)
- New distributor, TFI (Motorcraft), cap, rotor, wires, plugs
- New fuel pumps (in-tank and secondary)
- Fuel pressure 35-38 psi
- TPS reading 1.02V at rest
- ECT and ACT readings similar ~40k (not sure the exact value at the moment but both within 2-3k)
- New injectors (SKP mid range price from rockauto)
- New ECM (Blue streak electronics reman), however currently swapped back to original as it was even worse with new one
- No significant codes (only EGR which is ok because EGR is bypassed completely)
- New HEGO (o2 sensor)
- Most of the connectors for sensors are new. Questionable ones were replaced.
- Ignition timing set with strobe light at 10 degrees with SPOUT connector out
- New coil
- New FPR (Walker products made in USA)
Best regards,
Jerry.
