- Jun 5, 2021
- 2.9 V6
Focused on the interior today. Got the seat cleaned in anticipation of a seat cover and took the time to insulate the passenger door. Here’s the process:
I cleaned up the inside of the door with a solution of Purple Power. Once this was thorough, I applied butyl rubber over the factory vinyl or whatever it is in there. This REALLY helps cut down on the vibration and following the vinyl is really all that’s needed. 3M has a butyl substitute which is about twice as effective using half the material; had I known about this when I purchased the materials last year, I would have gone with it instead. Terrible picture, but gets the idea across. Ignore the overuse of foil tape to seal the gaps.
After that, I applied Frost King duct insulation—as I put on the cab floor—over a larger area. I then cut 3M Thinsulate SM400L to the same area and applied it with 3M 90 spray adhesive. Works, but is messy. The picture is of the driver’s side for the reason of it being prettier:
Here are the measurements in inches for the individual pieces (left to right):
2 x 18 3/4
16 1/4 x 18 3/4
6 x 18 3/4
7 x 18 3/4
I finished it up by sealing the top with foil tape so water doesn’t have a chance to get behind anything and will run onto the hydrophobic Thinsulate.
This stuff is, honestly, magic. My truck used to read 70-71 decibels at 65mph. After installing the Thinsulate just in the driver’s door, it dropped to 67-68 decibels. Doesn’t sound like much, but remember that the decibel scale is logarithmic. Insulating performance is just as good as the soundproofing, too.
No, I am not paid by 3M, nor anyone else.
I sourced the Thinsulate from diyvan.com and will be sourcing from them again to make backings for the door panels.
On another note, the u-joints and other parts finally came in and they will be getting installed in the coming days. Quick question I’ve been meaning to ask: this thing came in a Bucket-O-Parts the previous owner had from the work he did on the truck. I never figured out where this goes even though it’s probably something obvious. Any help?
2 x 18 3/4
16 1/4 x 18 3/4
6 x 18 3/4
7 x 18 3/4
