So, I’ve found that the clutch type if it’s been modified, tends to have a pretty predictable lockup but 4x4 definitely gets used more often. It almost acts like a locker in the winter. A normal clutch type can have a little more unpredictability in the winter.
A locker is very predictable but also requires 4x4 to be used a lot more because of a tendency to push the front end straight. Found that out the first winter I drove the F-150 with a Lock-Right in the rear. I had traction for days in 2wd… as long as I only wanted to go straight. Needed the front end digging to pull me around turns. I got to where I lock in the front hubs unless I’m doing highway driving in decent winter weather and use 4x4 as needed in the winter to keep me on the road. Try turning on your rear locker in snow in 2wd and you’ll see what I mean.
Lockers, and things that work somewhat close to them, at least around here, you can usually feel it try to kick the back end out, so I’ll back off the skinny pedal right away and try rolling back on it gently. In a stock limited slip, the back still likes to try to pass you, but if you have extra clutches and little to no friction modifier, it will usually respond more positively to throttle work to keep it steady. Or at least in my experience around here that’s the case.
