Hello, I’ve been reading through old posts about similar problems & I appreciate the help.
I have a 1985 ford bronco 2, 2.8 automatic transmission. Truck was running great up until one day it started stalling when put in gear.
Truck will start and idle fine but once shifted into forward or reverse It will stall and die.
Attempts to fix:
Truck is still doing the same things after all of this. Any help or info on the next steps to resolve the issue will be helpful.
thank you!
Attempts to fix:
- replaced torque converter
- replaced torque solenoid valve
- went through all vacuum lines & verified against diagram under hood
- cleaned valve body and filter under the pan
thank you!
