02 FX4 twin stick version.
CorbinsRanger
5+ Year Member
Saskatchewan
31x10.5x15
Saskatchewan...hard to spell...easy to draw
New to me Ranger after hitting some Government cattle with my 93. Seller just installed Rebuilt Trans and new clutch etc. with receipt was 3k. Had bald tires. Asking price was $8K. Settled on $6250. 197000 kms on the clock.
looks good
do they use salt on the roads in your area?
I was informed a few years ago that the term twin sticks is typically used for trucks with dual transfer cases. I still refer to mine as twin stick occasionally though.
Mileage at 197,000 seems mighty low to rebuild that transmission. I had mine done at around 240,000 miles and am sorry I did it. They replaced the 5th gear and reverse cluster. Those parts are no longer OEM and are now made in China. I have gone through two more 5th gear replacements plus a totally remanufactured one since then. I am on the second remanufactured one now, but plan to order another 5th gear for the rebuilt transmission in case the remanufactured one fails again. I am going to have the 5th gear parts cyrotreated this time to see if that helps. I hope they did not replace your 5th gear with the after-market one.
Enjoy, they are very capable Rangers.
Twin stick was oem? What's the engine?
Are those Canadian dollars or US dollars? Don't know if it makes a difference, at one time they were different.
Looks nice. Buckets?
RED Ranger (y)
Manual trans and manual transfer case, it doesn't get more reliable than that
Yes it was an option and those are Canuck Bucks....aboot 30 something % less. Buckets with weird inserts and all black interior/
Yes you are right two T-case sticks...one for crawl and one for....not crawling I guess. The kid I bought it from said he brought it in for a clutch at the shophe works at and was advised to rebuild it while it was out. Now you have me worried lol.
If it has the 4.0l SOHC engine be sure to change the 2 timing chain tensioners with motorcraft brand when it warms up a bit, 2001-2004 had issues, and all 4.0l SOHC engines should have these replaced every 100k miles in any case
Less than 2 hour job, tensioners are external access
Also if 4.0l SOHC, watch the thermostat housing for leaks, its plastic and cracks, there is a 3rd party metal unit now available
RED Ranger (y)
Always turning the front though from what I was told. Not that it matters. Pigs on fuel but hey....fun factor!
That one one passenger side though....ahhhhh. So nice of Ford to do that just so you could interchange heads. Brilliant!! And the thermostat housing is metal so it was already replaced. I will have to look at a video of doing those tensioners, although there is zero noise on cold starts but still...cheap insurance. Thanks and cheers from Saskatchewan.
Best Ranger ever built, a 4.0, 5 speed with a manual shift transfer case Is all I would own.
Sweet Home Alabama.....Where skies are......
And go Bengals. Went to 2 home games when Boomer was QB. Long time ago.
