- Mar 10, 2012
- 4.0 V6
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
So twice I've turned the key to start the truck and it pause a second before turning over and starting. This morning I turned the key and nothing happened! I held the key in the start position for a few seconds hoping it would start but no luck. The last time something like this happened it would crank but not start and it turned out that the fuse for the 12V feed to the coil was corroded. I recently had an issue with my drivers side door lock/unlock switch not working and when I went to replace it I found a couple of the pins were corroded. I cleaned them and it worked fine. So I am suspecting another corrosion case here but I'm not sure. I disconnected the battery and cleaned the post, though they were not too bad. While it was disconnected I pulled the PCM connector and everything is clean. I tried starting her up again but still nothing. It's not a PATS issue because the light doesn't flash and goes out. where should I check next? Oh, I also checked the PCM fuse and it's good.
