1989 Ranger Transfer Case Motor?
You are mistaken there sir, it will engage while going down the road, up to 55 MPH by the manual, possibly more if one should choose. I would not care to lock in a manual at 55
That's just 4-hi. For low range you need to come to a stop.
That is to shift back and forth between 2wd and 4x4 high, you can do the same with a manual transfer case.
I stand corrected fellas :) Wasn't picking up on that low range bit. I don't guess I've ever attempted going into low on the move. If it's that steep I'd have to wonder if it's worth the risk of it jumping out halfway up
I'll take mine out of low range while moving but haven't gone into low range while moving, I'm usually in sand and you either need it or not so more common to go out of low on the move than in... That's one advantage of a manual trans, less arms needed, easy to put your left foot down, not so easy to put the column shift in neutral then push the lever forward then back in gear...
No, it all depends on what you are doing, I have a 4 cylinder wheeling so I'm just in 4 low a lot since I don't have torque, it's just like downshifting your transmission, but when you're in first there's only one way to downshift from there... going slow is needed to get through some things either from needing power or to be less bumpy or get your tires where you need to...
I know that's right. I went through the woods here a few months ago for the 1st time in several years and it was full of cow tracks and it was all I could do to stand it idling in low 1st and that with a foot on the brake. Also I worried it could bust a shock or maybe something worse. Dry summertime here it's tough as cement and when it's good and soaked as it is now you just better stay out of it
Soon as I get a chance it needs a good front end inspection and possibly most of it replaced
You should really try driving faster through stuff, the TTB really takes it up, if there's nothing that is going to hurt the tires, faster is almost always smoother... that's what shocks are for, the old school speed bumps are much smoother at speed than going slow, those new big ones not so much unless you have a better suspension than my '97 4x2 has and you'd have to be going faster than parking lot speeds... when my '90 is riding the best on rough stuff my buddies say it looks broken :)
