Wiring harness help!
daniel.karrer21
Central Kentucky
I am currently building a 302 from a 1995 Mustang GT. I have a megasquirt plug and play ECU and the wiring harness, not including the fuse box, from the 95 Mustang. I need to figure out what I need to do to get the wiring harness from the Mustang to work with the harness from the power distribution box that's on the Ranger. The Ranger is a 1995 XLT 2wd.
I'm and trying to get the wiring harness I have from the 94 Mustang GT to work with the harness for the Ranger. Does anybody have any info on what I should do to get it to work? I've heard just PCM power and fuel pump power. The only thing I can find info on it for a 92 mustang harness into a Bronco 2 harness.
Just bumping up your first thread... really no need to start another thread for the same problem. These things need to soak a bit until the right person sees what you're asking an has an answer. I'm going to delete your second post. Hang tight.
Sounds like you need the EVTMs for the Ranger and for the mustang. Should be available on ebay.
