- Feb 1, 2022
- Germany
- Total Lift
- none...yet
- Total Drop
- not for me
Has anyone done a 4.3L swap? it seems like a good way to go. I'm not sure if the transmission would mount or if there is an adapter but even if it doesn't the Chevy/GM trans and transfer case should work. the after market is way bigger, the engines are cheaper, more available, and have more power. they seem to be around the same size maybe even a little more narrow from the SOHC 4.0L.
***edit: i know the 90* thing may make the GM/Chevy stile a little wider but if we can fit an LS why not a small block design V6
