o2 sensor locations on 1990 2.9l v6 ford ranger
stamina
Forum Member
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i know there is one right before the catalytic converter, that is all i know as of now, where (if any) are the other ones
Should be only one on a 1990 2.9L.
that word should🤦‍♂️i appreciate your feedback though🤙🏼
You should be able to find that info in the wiring diagrams.
You should be able to look at your exhaust and see how many you have.
My 1990 Bronco II has only one HEGO sensor. The 1990 EVTM (Ford wiring diagrams) shows only one HEGO sensor on the 2.9, both Federal and California.
So yours "should" have just one, but anything is possible on a 30 year old truck.
is a 'HEGO' sensor different than an o2 sensor? and is it right before your exhaust?
No, HEGO is the same as O2 (Heated Exhaust Gas Oxygen). On mine it's on the Y-pipe before the cat.
thanks so much got it figured out!
On a 1990 2.9l the O2 sensor's heater should be fuse 18 in cab fuse box, 10amp
