- May 14, 2021
- Age
- 53
- Missouri
- 3.0 V6
- Total Lift
- NA
- Total Drop
- NA
- My credo
- Just because I haven't been exposed to something to learn it yet doesn't make me stupid.
Mostly due to the fact that any spare minute I have, you can find me working on Rufus.
I've had to fix several little things here and there. Passenger door lock wouldn't open with the key. Dome light wouldn't come on when passenger door was open, etc. I repaired the plastic lid of the center console, cleaned the cover, reinforced and added padding and put it back together.
The biggest change so far was adding the fiberglass tonneau.
Next, I started chasing a roof leak which was soaking my headliner and dripping down everywhere any time it rained. That turned into mostly gutting the interior which is ok because it was stained and nasty anyway.
Found the leak is coming from the back window. Even after tightening the bolts, one corner won't draw down, so next step will be to remove the rear window and check/ clean the seal and reinstall.
I'm learning a ton and will post more as I progress on getting Rufus all spiffed up! lol
