Ok I'm back on the housing again. Ordered another one just in case. Got the aluminum one out and have the same issue with the sensors. The gray one fits in both holes and plugs in to both plugs. The brown sensor fits in both holes in the housing but wont plug in to either plug. The thinggy in the pic that I'm pointing at needs to be in the middle of the sensor to line up with the groove in the plug. The other new brown sensor is the same way. The old ones I took out are gone but the sensors were too small to seal in the holes of the new housing. Both new housings are the same diameter for the sensors that came with them. I tripple checked when ordering from partsgeek that thw housings were for a 06 4.0 but the sensors are bigger on the new one's. Not sure what to do from here. The truck runs like garbage since I put the new housing in so im guessing the computer is reading that the coolant is hot or something like that. Also both gray sensors plug in both plugs and fit in thw housing. Probably not ok to use both gray ones I'm guessing.
