wildbill23c
- Aug 22, 2012
- Southwestern Idaho
- 2.9 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70-R14
- My credo
- 19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
The rear wiper on my Bronco 2 works, as does the washer...however not sure who thought up the ridiculous wiper arm design but the wiper is 100% useless it doesn't really make any contact with the back window. Wish there was a way to switch to a newer style arm with a normal spring type wiper blade like what's on the front rather than a flat blade with a nut and bolt...same useless wiper blades they use on HMMWV's in the military, they're useless LOL.
For the longest time the rear wiper never worked. I was doing something around the rear hatch area, and had to remove the trim piece on the top just inside the hatch opening. I found a wire up there with an eyelet on it, not connected to anything. I had always assumed the rear hatch had been replaced or something and was never wired in, or a bad switch, wiring, etc. No, it was just a ground wire was never hooked up. The wire was there but never attached to anything it seemed, as I never could find a place that it would have been attached to, no hole from a screw or anything anywhere close. I put a self tapping screw and washer through it and it works but like mentioned above its useless thanks to a horribly designed wiper arm/blade assembly. Wonder if I could grab a arm/blade assembly off an Explorer?
