What size brake line should i get
Madracingalley
Gansevoort, NY
1994 Ranger Xlt S/C
14 inch tires
4.0L 5- speed
I blew a brake line in front of mineke and they asked for 400 buck so i decided to take the free tow home now i need the size for the brake line
And are they flaired
Front or rear hard line blew? Either way you will need 3/16" tubing
the steel line that goes from the Jct. box in the front to the rear behind the gas tank which i just filled :yahoo:
You don't have to drop the gas tank, just cut the old lines, yank them out and run your new ones along the fame between the tank. It doesn't have to be one solid line, you can get the premade lines from most any auto parts store and just use unions to connect them. Then if you ever have a leaking line in the future you can just undo the unions and replace the 1 section. Good luck.
