Ranger crossover steering
Cradh
5+ Year Member
Sparta, Michigan
Anyone building a crossover steering for a 91 ranger
That does not work on TTB axles so I'm guessing not. If you have an SAS it would have to be something fairly common for it to be made.
What is your suspension setup and what issues are you trying to solve? If you put in a 4" or more lift and haven't changed the pitman arm on the steering box and just had it aligned it probably drives bad... get a Skyjacker FA600 arm and put that in and it should help a LOT, aside from that I think Skyjacker is still making the superrunner steering, if not there might be something similar around
