- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
You drive a fiesta.That's illegal and immoral.
You drive a fiesta.
That's what I was afraid of with the SOHC.I wouldn’t buy anything from that place because of this:
If you put a list of “keywords” that have nothing to do with the item you’re selling... **** you.
That being said, I don’t like the 4.0 SOHC. It was a terrible design. I’ve seen way too many timing chains try to escape through the valve cover.
They had a major issue with the bad design, tried to fix it with a bandaid, then gave up and discontinued the engine... what does that tell you? Yes, the newer ones are better but a normal shit is better then diarrhea.
I dont think the 2.3 was in any 4x4 after 01, or maybe 98.That's what I was afraid of with the SOHC.
The irritating thing is that I'm looking for the exact same truck layout, 2008+ with the 2.3 for a commuter truck for work. Yes, I know the 2.3 wasn't available in the fx4. But same general setup, x-cab, 4wd, manual, etc. The fx4 in this case is just a nice bonus.
Not any more. I finally hit puberty.You drive an escort!
Oh ffs ford.The 2.3 didnt come in 4x4... all 4x4's had the 4.0.
Prolly cause youll never find a duratech 4wd tranny.Oh ffs ford.
And let me guess... A 4wd conversion or engine swap would be a stupid amount of work.
I like the rear discs...![]()
The timing chain itself is rarely, if ever, the issue. The hydraulic chain tensioners are the problem. They have a spring to hold tension when pressurized oil is not available (like during cranking) that wears out. That plus if the maintenance was poor the tensioner can not hold good pressure against the chain, which allows it to slap against the guide, eventually breaking it. The tensioners themselves are not expensive, nor difficult to replace.Figured the 8500-8750 range was a good deal.
What's the lifespan on the SOHC, and average total miles before its dumb timing chain needs to be replaced?
