Do you need to remove the hub on a 03 Dana 35 (4.0 4wd) to get the CVs out? I am dropping my diff for a rebuild and got to where I can almost pull them but I just don’t quite have enough sway. Will they come out when I drop it?
I pull the tie rod and lower ball joint out. swings out far enough to pull the stub out. (in)
as it is you may be able to pull the inner joint from the diff and leave the axle assembly in place.
pull hard, there is a clip in the splines that holds the joint in the diff.
I was able to get right side out today and left is enough that it will come out when take the mounting bolts off (didn’t need to take anything else off but the shock so I could get a better grip on the axle. Do you remove the whole frame mount or take out the 3 bolts in the side of the diff?
