- Dec 1, 2018
- Austin, Texas
Hey fellow rangers, through a slew of craziness after my starter motor died some 6 weeks ago, I've somehow found myself in a extremely newbie mechanic situation. There is only one line ran from my fender mount relay down to my starter solenoid, which is attatched to my starter motor. One wire from my relay. Can anyone explain to me why I have two wires running down from what I can tell as my relay? And I don't mean two counting the thin little ignition wire, I mean I have two thick gauge wires that come down to my starter inside the same line, one red and one back, both with the same size wire and clipped onto the same little mounting bracket under my steering column, that run together as a pair from start to finish. Somehow I managed to get myself all turned around and believing one was a hot and one was a ground, and have not been able to get my truck to start despite replacing the starter motor, starter relay, battery, and using a voltmeter to verify I have 12.5 volts running from battery to relay, verifying my voltage drop was within .5 when turning the key to start, tested the starter motor with jumper cables and a jumper wire when it's no bolted to my truck and it works everytime flawlessly. But when I bolt it to my truck I can not through turning the ignition, using a jumper wire to bypass the ignition, jumping at the relay, no matter if I have either one wire connected to the post, or both.
Please someone help a guy out, everyone I know who has offered insight says thay cant imagine how I'm possibly finding myself in this situation. Thanks in advance, long time forum lerker-first time register and thread maker, James
