wildbill23c
10+ Year Member
- Aug 22, 2012
- Southwestern Idaho
- 2.9 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70-R14
- My credo
- 19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Jukkak is spot on. The relationship between flush and destruction is a case of mistaken causality.
A lot of techs who don't know much about transmissions (I am included in this group) will get handed work orders for poor shifting, or some other fairly minor issue, recommend flushing the trans because new fluid cleans and lubricates better, and often poor shifting is a sign of something getting stuck in the valve body. The customer approves the flush thinking it is a fix-all kind of thing, rather than a "Well let's start by getting your basic maintenance up to date" thing. Then because the issue was more serious it actually breaks a little while later, after it seemed good. They then assume, because all customers think this way, that the flush must have damaged something inside the trans. So they go tell their idiot brother in law, who tells his idiot co-workers, and pretty soon the whole world thinks that regular maintenance, especially if it was overdue, is going to break their car.
The truth of the matter is if you change your fluid and the trans breaks right away it was on borrowed time already because the dirt was all that was holding the guts together.
This is very true. Many think changing the fluid/filter is what kills the older transmissions that have been neglected. Usually if the transmission is in good working order, changing the fluid and filter isn't going to be a problem. Its those old neglected questionable transmissions that have shifting issues already that will most likely suffer a failure due to changing fluids. The fluid picks up debris from the transmission over time and changing that fluid can cause the transmission to start slipping and not shifting because the new fluid is more slippery so parts start slipping rather than working as they should...worse is doing a flush because that will usually break up stuff and send it throughout the transmission causing further problems...its just best to leave a questionable transmission alone.
In a transmission that is functioning properly that you don't have a record of service on I'd do just a fluid and filter change and let it be. Far less failure problems from changing fluid and filter compared to flushing from what I've gathered over the years.
If its working now a simple fluid and filter change should be just fine.
