I recently purchased a non-running 1995 ranger. The previous owner stated it was not running due to a timing/compression issue. First thing I did was put a new timing belt on, I was careful to make sure all timing marks were lined up, so timing is good. Last night I ran a compression test Cylinder 1-115, 2-0, 3-0, 4-0. This is a bit puzzling! I ran the test through twice just to make sure.
I know it is highly unlikely that there would be broken rings, or stuck valves on 3 cylinders. This morning I pulled the valve cover just to make sure the cam was in one piece. Cam and valve train seem to be rotating normally. So I'm thinking this has to be a head/head gasket issue. Am I missing something??
