- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
2.9l Number 3 cylinder exhaust lifter issue?
Need Help Guy's
I been dealing with this popping bogging 2.9l for some time now. I been hearing a loud rocker tick as it is popping I pulled number 3 plug carbon fouled as always. I just pulled the valve cover off number 3 cylinder the exhaust rocker has lots of slack I can push it up and down easy. All others are snug no slack the lifter must not be pumping up thus a loud popping sound. Is there a way to help this maybe adjust the rocker down take some of the slack out? I think the popping is the exhaust valve no opening
I just took the coil wire off turned it over 20 times to bring the oil pressure up. Number three cylinder exhaust lifter still has lots of up and down movement all others pumped up no movement. I can see lots of oil on top of the lifter as I push the rocker up and down
Here is one of my other threads of my on going saga http://www.therangerstation.com/forums/showthread.php?t=171327
Need Help Guy's
