Junk Yard Ranger
JunkYardRanger
Orlando Fl
Here is some pics, Before during and almost the after. All I have left is brake lines, steering, shocks, drive shafts and some small stuff
The truck has a total of 16 inches of lift with the 3 inch body lift.
Dana 60 in the rear, Dana 44 HD in the front in a few months it will have a divorced case also
My buddy Alan welding
the cab is original minus the drive door the fenders are original the front and rear are out of a 77 250 high boy I picked up dirt cheap tires and wheels are from another web board rear springs and blocks are also out of the 77 so all and all the only new parts in the build is front springs, bushings, brakelines, pitman arm, and of course brackets and bolts ... and the motor is out of a 98 explorer, trans is out of a 96 ranger, driver door is off a 96, bed is off a 99 header panel is off a 97, transfer case is out of a 95 explorer, and the seats and console is out of a 94 explorer ..it is a true mut but all FORD:headbang::clapping:
