- Mar 12, 2011
- Edinburg, TX
- My credo
- Fix it till its broke!
Ok so I wired in a universal wiring harness on a trailer I'm restoring and same for my truck to tow said trailer.
My problem is that I've gotten everything wired correctly on the trailer and it works. On the truck though all lights through the harness work except I have no brake lights on the trailer but they are working on the truck.
In other words the trailer has no brake lights but I did test things and see that the wires for the turn signal don't light up when braking because I have 3 bulbs brake, reverse, and signals. So am I correct in assuming this needs to be wired differently than what the tech section here says? Do I need to splice into the brake light? I spliced in where the harness comes to the test before splitting off to the separate left right tail harness.
Am I missing something? I got brown to brown black to white, orange/blue to green, and lt green/orange to yellow. Running lights work, turn signals work, but when the brake is pressed they don't get brighter. They do get brighter with the turn signal and flash, and they stay lit just not as bright without the flasher or brakes.
Any ideas?
Any ideas?
