Keto
- Apr 28, 2014
Heya Guys,
Could use some help... 1996 3.0L, manual trans.
Not too long ago I pulled the blower motor/fan, cleaned out the box, cleaned the connectors, and replaced the resistor since I had everything off. Was working fine until today, noticed the heater seemed to be stuck on stupid.
Went to check everything, and took a look at the heater hose control valve. pulled he vacuum line off to inspect, and it seemed loose. Proceeded to follow the line when I realized the other end was broken and just hang'n there
I didnt check that line last time, so I have no idea where the other end goes... been looking around but so far its not jump'n out at me.
SO, where is other end of that vac' line located? Any info or pics would be appreciated!
