I don't get it. I spent 2-3 hours reading and I don't think I read one post with the same issue.
94 ranger was running "fine". Failed emissions due to cracked fuel filler neck. Replaced it. Truck ran. Then I got the bright idea that I might as well change the fuel filter. Put a nice new healthy one in there. Got the filter off fairly easy, guess I got lucky there. Clips weren't too bad. Put new filter on, and yes I put it on the right way. Drove for a little and now truck no run.
Pump turns on with ignition. Checked inertia switch. No pressure at valve on fuel rail. Tried turning on and off at least 20 times. Sprayed starter fluid into intake and it fires up for a few seconds then dies. Truck has at least 5-6 gallons in it. Maybe more like 10.
I forgot. When it first wouldn't start, I thought it was weird because gauge read 1/4 tank. Tried putting more gas in thinking maybe float was bad. Shortly after I started putting gas in, it started overflowing out the filler neck. Weird. I thought something with new filler neck. When I squeezed the filler neck towards the bottom, I could hear the gas starting to flow down as I squeezed. I thought something weird like somebody put some shit in my tank or something, but now seeing no pressure at the rail it kinda makes sense.
But why?? Any thoughts?
