The 25 dollar challenge. $25 via paypal to the first person with the
correct diagnosis. If you don’t believe me then don’t help, but the
way I see it there’s nothing to lose so all help is appreciated.
Trying to find someone to actually read through what I’ve done and
give it some real thought as my head hurts from doing so, and I’m
nearly out of ideas.
The truck:
97 ford ranger ext cab 4x4, 4.0 vin x, m50d manual trans, BW1354
manual transfer case, 8.8 31 spline exploder rear with discs and
4.10s, 33x12.50s, 330000mi on the truck, 80000mi on the engine.
The problem:
-My O2 sensors all read 0.000, yes all three of them. This is causing
my fuel trims to all read -100.0. The VSS also reads 0 all the time.
-These readings have all been taken live during every possible driving
condition I can create and they have all been on three different
scanners including the stupid expensive snap-on type. I have MIL
indicating lean bank 1 and 2. Understandable considering the sensors.
-The truck runs alright, starts, runs, doesn’t die, and throttle
response isn’t bad. Definitely smells rich though.
What I’ve tested/tried:
-Checked all fuses- all good
-Cleaned MAF- no change
-Checked voltages to MAF, IAT, TPS, Temp sensor- all within range
-Tried 3 different DPFEs I had access to (correct part numbers)- no change
-Checked Voltage to DPFE- within range
-Checked voltages to O2 sensors- (key on) 12.5V in (heater), 2 grounds,
nothing in or out of 4th wire on all 3 sensors
-Replaced one O2 sensor-no change (shot in the dark)
-Borrowed a PCM with matching #s- no change
-Triple checked with multiple dealers that the PCM was correct part
number for the truck. (discovered it’s a 49 state truck)
Conclusions:
Somehow I think I’m losing VREF to the sensors and VSS. My only
remaining ideas are:
-the wiring harness is incorrect for the computer pin connector
-I have an open VREF wire for the sensors. However the VSS and O2s have
different VREF supply based on the wiring diagram.
-I managed to diagnose 3 bad DPFEs. Based on the wiring diagram I
can see how they would mess up the O2 sensors.
-I somehow opened a loop on the lower wiring harness by disconnecting the electric transfercase to put in a manual.
As stated $25 via paypal for the right diagnosis. I should have the
answers to any followup questions, if I don’t then maybe you’re on the
right path. If you come up with the answer on wred or thurs I will tell you but you may have to wait till Friday for me to get paid as this project is expensive.
Thanks, Kirk
The truck:
The problem:
Conclusions:
Thanks, Kirk
