Materials:
Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL
Vehicle:
2019-2020 Ford Ranger
Check:
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Remove the front differential fill plug.
3. Check and top off the differential with clean differential gear lubricant. The differential gear lubricant level should be to the bottom of fluid fill plug opening.
Material: Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant / XY-80W90-QL (WSP-M2C197-A)
4. Install the front differential fill plug. Torque: 21 lb.ft (28 Nm)
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
