| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Need Urgent Help Fast! |
Thread Tools | Display Modes |
#1 |
Year: 1994
Make: Ford
Model: super cab
Engine: 4 cycle 2.3L
Class: 2WD
Used For: daily driver
Rep Power: 0 ![]() iTrader: (0)
ok so my cooling gauge used to sit right smack dab in the middle. Down the road i replaced the water pump and did a cooling flush and no problems. Recently i had to put a radiator in cuz the oem one finally went. now the temp gauge sits on the low side, right on the normal line. It just stays right there and goes down beyond the normal line sometimes (guessing when the thermostat opens or fan kicks on). So i Replaced the thermostate. I put the hole towards the top no air in the system and rewarded with amazing heat but still the same problem. I noticed my fan was always on so i replaced the clutch so it funtions properly today. still same problem. Now is my temp sensor just crap and needs to be replaced or am i missing somthing. new radiator, new water pump, new thermostat, coolant level is good heat is good cooling fan operates as it should its just that damn gauge just sits on that line and drops outta normal. i want to make sure im getting up to operating temp and not burning alot of gas.
any help be great Last edited by krazykooters; 01-04-2011 at 08:44 PM. |
Tweet
#2 |
Year: 1988
Make: BroncoII
Model: Ford
Engine: 2.9
Class: 4x4
Used For: D.D and wishful thinking
Rep Power: 10 ![]() iTrader: (0)
check the wiring connection if it has a temp sender.
and the inside contacts might be gummed or corroded good luck
__________________
We are here till we are not and we agree! _______________________________________ explorer springs and front d35 with coils just gotta put em on damn rusty bolts ![]() |
Tweet
#3 |
Junior Member
Year: 1992
Make: Ford
Model: Ranger XLT
Engine: 4.0L
Class: 4X4
Rep Power: 12 ![]() iTrader: (0)
get a multimeter and test that temp sensor.... could be bad sensor, or a bad connection as the PP stated.
Tweet
#4 |
Year: 2002
Make: Ford
Model: Ranger Reg Cab
Engine: 2.3L
Class: 2WD
Used For: DD/Fun
Rep Power: 6 ![]() iTrader: (0)
i agree with ranger danger. check that temp sensor.
first thing i was taught in school was the wiggle test. check for loose connections. visually inspect the connectors and the wires. good luck man. |
Tweet
#5 |
Year: 1999
Make: Ford
Model: Regular Cab, Styleside,
M5OD,
3.73 open 7.5 axle,
RABS,
139k(3/08/2012),
no A/C,
Engine: 2.5(5w30)
Class: 2WD
Used For: As a Turd Vehicle
what degree t-stat did you put in. was it different then the one that was in there. when working properly these engines run cool.........
Tweet
#6 | ||
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
Rep Power: 21 ![]() ![]() ![]() iTrader: (0)
nothing wrong with it, just a low temp thermostats, mine stays on the n of normal all the time. I get good heat too.
__________________
This signature has encountered technical difficulties... Quote:
Quote:
Tweet
#8 |
Junior Member
Year: 1992
Make: Ford
Model: Ranger XLT
Engine: 4.0L
Class: 4X4
oh its at the "N".... well then thats NORMAL ahhaha
my 92 4.0 runs around the same area when its all warmed up. It used to run hotter and flucuate... but then a put a new thermostat in it. Still gets good head. I think everything is normal. Originally i thought you were saying its sitting around the "C"... which would be too low.. |
Tweet
#9 |
Year: 1994
Make: Ford
Model: super cab
Class: 2WD
yea it gets in the normal zone lines and but is just sits on the low side...but all is good long as it in the normal zone. Thanks for the help
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
