- Jan 27, 2008
- Age
- 41
- Automatic
i am undergoing a 302 swap.i fabed my mounts and raised the motor slightly,installed low preasure fuel pump,installed oil filter relocator.for ignition wired that up,i first tried the duraspark out of a 85 f-150 this is my donor.the wiring was all hacked.got it put back together and just had three wires to hook up into the truck.there were two red wires and one white.the two reds i was told by a local mechanic needed to be hot wires when the ignition was in the run position.and the white was to be hooked to the solenoid, so there would be a pulse sent to the distributor.hooked him up and nothing.got frustraited and my dad told me to get a points one they are much easier.so got that bad boy.hooked him up with the one wire on the positive side of the coil.nothing.then another guy told me that it is supposed to be hooked on the negative side of the coil.does this make a difference?cause both sides of the coil are hot with only one hot wire hooked into it.is this how its supposed to be?runnin out of ideas and getting frustraited with it.any help or insite is much apreciated and valued.
