Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Wheels & Tires
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-25-2010, 04:46 PM   #1
NoBoundaries
NoBoundaries's Avatar
Year: 2007
Make: Ford
Model: Ranger FX4 Level 2
Engine: 4.0L V6
Class: 4x4
Used For: everyday use
NoBoundaries is on a distinguished road
Default 33/11.50/15 or 33/12.50/15
I have a stock 2007 ranger fx4 level 2 I have the stock 31/10.50/15 bfg's on my 7.5 alcoa's right now, now heres what I want to know Ive been looking with nothing coming back on 33/11.50/15 tires of any make maybe someone else would have better luck idk.
2nd question is will 33/12.50/15 fix with no problems at all no rubbing turning ect any help would be great and Id like the tire to be a mud tire or a aggressive a/t.
thanks
NoBoundaries is offline   Reply With Quote
Old 12-26-2010, 01:28 AM   #2
frankserrano
frankserrano's Avatar
Year: 2005, 1986
Make: Ford
Model: Explorer Sport Trac, Bronco
Engine: 4.0L, 5.0L
Class: 2WD, 4x4
Used For: Business & Pleasure
frankserrano is on a distinguished road
Default
33/11.50 is an uncommon tire size. if you're set on the 11.50 width, then look for 32/11.50, which are much more common.
as far as 33/12.50, with a t-bar twist, you'd easily clear the height of them, but the width would likely rub a hair at lock to lock steering.
__________________
"build it, drive it, love it."
frankserrano is offline   Reply With Quote
Old 12-26-2010, 01:36 AM   #3
clifford97
clifford97's Avatar
Year: 1997
Make: ford
Model: ranger- (not a danger ranger!)
Engine: 3.0
Class: 4x4
Used For: DD, fun!
clifford97 will become famous soon enough
Default
i have 33 12.50's with knoby mudders they do rub some times but you have to have it cranked all the way to one side and its not too bad then even, although i have a lift so idk if you have anything else that could be in the way..
__________________
just my $.02
"I knew you were going to get stuck. you thought u were in your ranger, you forgot you were in a jeep"
clifford97 is offline   Reply With Quote
Old 12-26-2010, 02:17 AM   #4
NoBoundaries
Year: 2007
Make: Ford
Engine: 4.0L V6
Class: 4x4
Default
Quote:
my level 2 is stock no lift no nothing if I really have to Ive been looking and only looking at the superlift 3 to 5 inch suspension lift all this tires and all that is just looking for now when I have the money then I'll know what I want and wont have to worry about going through and looking
Old 12-28-2010, 03:16 PM   #5
feellnfroggy
feellnfroggy's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
I HAVE A STOCK 1993 with no lift whatsoever. Im running 33x12.50s on 8 inch rims. the tire itself will fit fine on your rim however your truck is a different story, I dont rub at full lock but at slightly less than full lock, my side lugs grab the fenders at the rear bottom corner in the front. It all rubs bad If I stuff them. But it drives ok for me right now, and I am TTB I dont have torsion bars to lift it 3 inches. You will experience an insanely rougher ride at 3 inch Tbar crank, I would do it past 2 inches.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 01-11-2011, 07:15 PM   #6
spiff-d
spiff-d's Avatar
Year: 2009
Make: Ford
Model: Ranger Sport 4x4
Engine: 4.0L
Class: 33x12.5R15 Awesomeness
Used For: showing other 1/4 tonnes whats up.
spiff-d is on a distinguished road
Default
I have Goodyear Wranglers Duratracs 33x12.5R15's on a a 15x10 with 3.75 back spacing on my 2009 Ford Ranger Sport 4x4 and I had to do some trimming in the front, and crank the t-bar with my pre keys but they fit well.
They rub at full lock and occasionally rub on the flair at certain times, but other then that it's A-Okay!
- Spiff
__________________
"It's Better To Keep Your Mouth Shut And Appear Stupid, Then To Open It And Remove All Doubt."
spiff-d is offline   Reply With Quote
Old 01-11-2011, 10:49 PM   #7
canyoncritter
canyoncritter's Avatar
Year: 1952,1991,1992
Make: Willys,Ford,Jee
Model: wagon,ranger 4x4,cheroke
canyoncritter is on a distinguished road
Default
goodyear use to make a 33x11.50x15. in the GSA I think it was. not sure if they still make them or not
__________________
Why are women so dam expesive?....cause they are center cut.
canyoncritter is offline   Reply With Quote
Old 01-11-2011, 11:37 PM   #8
EERNGER
EERNGER's Avatar
Year: 2002
Make: Ford
Model: Ranger Xlt 4-door
Engine: 4.0L SOHC
Class: 4x4
Used For: Wheeling/everything else
EERNGER is on a distinguished road
Default
There is a 33x10.5x15 that i know bfg makes, if that is a viable option to you.
__________________
2002 Ranger 4.0L, AFE box filter,hurst shifter 4.10Trac-Loc,1" Pa body lift, Dynomax exhaust,garmin 60csx,4 hella 500's w/xenon
http://www.cardomain.com/ride/3341160
EERNGER is offline   Reply With Quote
Old 01-23-2011, 12:25 AM   #9
NoBoundaries
Year: 2007
Make: Ford
Engine: 4.0L V6
Class: 4x4
Default
Quote:
yeah I notice that guess I'll just have to see what I want I may just go with the 32/11.50/15's but idk yet
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
