| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Need Urgent Help Fast! |
Thread Tools | Display Modes |
#1 |
Year: 2006, 1994
Make: Ford
Model: Ranger, Explorer
Engine: 4.0 SOHC, 4.0 OHV
Class: 4x4
Used For: Pavement Poundin'
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (0)
Just installed new water pump, put everything back together, start filling it with antifreeze and its leaking between block and pump. Took it back apart, removed the gasket, used blue rtv instead. I have it bolted back up and waiting for it to cure. I had cleaned off the surface as best I could the first time. Should I have tried using the gasket again? How long should I let rtv cure before filling? Any other suggestions or recommendations welcome. I'm gonna start reconnecting the hoses and pray it doesn't leak again...
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 45k miles 1994 Ford Explorer Sport 2-dr 4x4, 178k miles |
Tweet
#2 |
Year: 2002, 2005, & 2
Make: All Fords
Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
Engine: 3.0L/4.2L/5.4L3V
Class: 2WD/4x4
Used For: Original Daily Driver/New DD
Rep Power: 9 ![]() iTrader: (0)
Did you use RTV with the gasket? You should have. However, the RTV should be fine without the gasket make sure you insert all the bolts had snug them then go through and give them a good torque. The RTV should be good to go afte an hour and fully cured in 24 (I think thats what the packages says). Good luck.
Tweet
#3 | ||
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
Rep Power: 20 ![]() ![]() ![]() iTrader: (0)
I always used just rtv. It should be good immediately once you bolt it down, go ahead and fill it and see if it leaks.
__________________
This signature has encountered technical difficulties... Quote:
Quote:
Tweet
#4 |
Year: 2006, 1994
Make: Ford
Class: 4x4
I used just rtv without gasket. I thought I saw a small drip on the corner, so I smeared a little more rtv on that corner and it stopped. Its been holding tight since. I filled it up and drove it around the block and its good. I'm not sure if I should drive it to my girlfriend's tonight or if I should let the rtv cure first.
__________________
Tweet
#5 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 76 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I've always used the red high temp gasket goop (silicone) on water pumps and never had one leak...it's doesn't work too good when it contacts gasoline, but that shouldn't affect the water pump...
__________________
Rome and my Ranger were not built in a day... |
Tweet
#6 | |
Premium Member
Year: 94
Make: Ford
Model: Explorer
Engine: 4.0
Class: 4x4
Used For: Getting my RBV fix
Rep Power: 11 ![]() ![]() ![]() ![]() iTrader: (0)
Just to sate my curiosity, with 28k miles on an 06, what happened to require such intensive work?
__________________
Quote:
84 BII 4x4 2.8: RIP 94 Explorer 4x4 4.0/M5OD/1354M: DD
Tweet
#7 | |
Year: 1987
Make: Ford
Model: Ranger
Engine: 302
Class: 4x4 Extreme
Used For: crawling over jeeps
Rep Power: 18 ![]() iTrader: (1)
its just a ford, it was feeling neglected and decided it had a need to mark its territory
__________________
if ur from jersey, get up on this forum http://njmudtruckshome.freeforums.org/index.php Quote:
Tweet
#8 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
when you use the rtv, put it on, then tighten all the bolts by hand. let it dry for 15-20 minutes and then go back and torque everything down
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#9 |
Year: 2006, 1994
Make: Ford
Class: 4x4
This wasn't the Ranger, it was the Explorer. With 16 years and 157k miles on the original water pump.
__________________
Tweet
#10 | |
Premium Member
Year: 94
Make: Ford
Model: Explorer
Engine: 4.0
Class: 4x4
Much more logical lol. I guess I should have read rather than glanced. =D
__________________
Tweet
#11 |
Year: 2006, 1994
Make: Ford
Class: 4x4
Well it held up for a few days, but it's leaking AGAIN.
![]() This is NOT how I wanted to spend my New Year's Eve. And it's a REALLY good thing my mother decided to drive the Accord 20 miles away just now, instead of the Explorer (like she normally does) otherwise I wouldn't have noticed and it would've probably all leaked out on the road...
__________________
Tweet
#12 |
\----===FoMoCo===----/
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
Rep Power: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
Me and RTV silicone don't get along. There was a guy who I used to work with that built engines. I was explaining to him an exact episode as you that I had with my Mustang. The RTV kept blowing out after an hour or two of use. He said "quit using that RTV junk and use Permatex #2 Form-a-Gasket". He told me the RTV starts making a skin as soon as it comes out of the tube, and if it takes you a while to get it all buttoned up, it won't seal properly. The gasket maker never hardens, and is very tacky, I've never seen it blow out. I've been using it for about 12 years ago with no leaks whatsoever. I also always use the gasket.....and put the stuff on both sides.
Here's a link to the stuff. I know it will work, first time if you use this.....no issues. http://www.permatex.com/products/aut..._2_Sealant.htm Last edited by shane96ranger; 12-31-2010 at 12:05 PM. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
