Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 12-18-2010, 11:15 AM   #1
geck0
Year: 1986
Make: FORD
Model: BRONCO II 4WD
Engine: 2.9
geck0 is on a distinguished road
Exclamation 1986 bronco II atx with shutter on aceleration
As the title says, when I accelerate I have a very fast shutter while accelerating (did it with original driveshaft and still but less with new U-joint style driveshaft) now I read on all data about some cross member update that replaced the original (mines the original) something about it causes the shutter so i called ford with the part number of course its too old they don't have it nor have a picture or description of what made the new one different. So then I ask if they have a master tech that was there back in the 80 and 90's, they did and he said (to the best of his memory) it was a taller trans support that changed the angle and he said i could try just shimming my old one with washers but that he wasn't sure.... Any ideas?
geck0 is offline   Reply With Quote
Old 12-19-2010, 11:51 AM   #2
jhammel85
Capt. Slow
jhammel85's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
Used For: Daily Driver / Off Road from time to time
jhammel85 has a spectacular aura aboutjhammel85 has a spectacular aura aboutjhammel85 has a spectacular aura about
Default
Where do you feel the shutter? Is it in the steering wheel or do you feel it in your seat? Is it only in acceleration? Any certain speeds that you feel it too?
__________________
-1987 Ranger 4x4-
3" Body Lift, 2.9 V6, A4LD auto, Manual Hubs, Dynomax Super Turbo Exhaust, 30x9.5R15 A/T, 15x8 Cragar Soft 8 Wheels
jhammel85 is offline   Reply With Quote
Old 12-19-2010, 12:37 PM   #3
geck0
Year: 1986
Make: FORD
Engine: 2.9
Default
its now under acceleration after its warm and i've driven a bit it happens sometimes even starting from a light, but usually its like 2nd and third,
i feel it in the seat, and its weird its like it jumps forward, its not like a lagging its more of a foward jump in the seat and floor, my wife was in the passenger seat and she felt it.
the thing that worries me is sometimes it gets violent and i have to back off, then re-accelerate, usually it doens't but sometimes its like the back end starts hopping, i've been into the rear diff it looked ok at a glance, standard slim cam out. maybe i missed something. or a axle bearing? i dunno, i'm just hopping its not the tranny.
I dunno if it matters but my rear leaf springs seems pretty saggy. which may go along with why they made this supposed taller trans tail support?
Old 12-19-2010, 08:06 PM   #4
geck0
Year: 1986
Make: FORD
Engine: 2.9
Exclamation
went out looking at christmas lights in the bronco (great back windows for the boys to see) and i've come to realize i do think its a slipping trans, i think i was miss judging it...so the next question is... It's a A4LD trans.... should i buy another trans and rebuild it to install, or upgrade to a better trans? whats the best route to go, its mainly a road vehicle my do some off road but nothing major (would love to just no time)
Ideas?
Old 12-19-2010, 08:36 PM   #5
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Used For: Everything
The_Dealer will become famous soon enough
Default
c5 if u wanna keep auto fm146 or m50d for stick
__________________
85 b2/fm146/bw1350
D'sparked,built, Holly'd 2.8/4" SJ coils/Explorer leaves/3" blocks/ shortened Explorer driveshaft/ 2.5" pivot drops/30x9.50 MXT's/Roofrack/HID's/ Autometer guages
Comming Soon:1" body, 33's, LED tail light boxes
The_Dealer is offline   Reply With Quote
Old 12-19-2010, 09:48 PM   #6
geck0
Year: 1986
Make: FORD
Engine: 2.9
Default
Is the C5 auto a direct swap or need new shafts and all? (in a tight budget) and is the A4LD that bad? Like if i got one cheap and rebuilt it am i just doomed for future issues?
also what do most wheelers run? I assume manual?
Old 12-19-2010, 09:50 PM   #7
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
not a direct swap.
a well built a4ld is fine for a truck like yours though.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 12-19-2010, 10:07 PM   #8
geck0
Year: 1986
Make: FORD
Engine: 2.9
Default
I guess it's time to start lookin for a A4LD...
Old 12-19-2010, 11:01 PM   #9
The_Dealer
The_Dealer's Avatar
Year: 1985
Make: Duh!
Model: Bronco II
Default
personally i would go with an fm146 or m50d-r1. i got all my swap parts for 55 bux shipped. pedals, slave, lines, master, resi. both of those trannys are the same length as an a4ld so no moving the xmember or driveshaft changes
u will need:
pedal assembly
master cyl
slave cyl with throw out
clutch lines(will need lines and slave for 92+ with m5od if u do that trans)
flywheel
clutch kit with pilot bearing
and i believe thats it, im going to be starting on mine soon, just gotta get a trans, flywheel, and clutch kit
__________________
85 b2/fm146/bw1350
Old 12-19-2010, 11:33 PM   #10
geck0
Year: 1986
Make: FORD
Engine: 2.9
Default
yea but as i said before I don't have all the time to do that, I was lookin for a good quick swap I guess i'll just do the A4LD but just find a good one and have it gone through, gotta find a good priced one
__________________
1999 volvo v70
1999 Saab 9-5 2.3lpt Stage 3+, 24lbs boost 288whp 295wtq
1982 Fiat spyder 2000... not finished collecting dust
1986 Bronco II 4x4 88k now being modified
Old 12-20-2010, 08:23 PM   #11
jhammel85
Capt. Slow
jhammel85's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
Default
I would agree about another auto. I know it might be out of your price ranger (1000 or so?) but Advance auto offers new AL4D's. "Heavy duty" ones too. Each come with a warranty.
Are you 100% sure about it going out? If it's doing it warm, I'd have to wonder about the condition of the fluid itself.
For starter's try checking the fluids level and see if it smells burnt (if it's slipping, it just may)
__________________
-1987 Ranger 4x4-
Old 12-21-2010, 11:44 AM   #12
Shran
Shran's Avatar
Shran will become famous soon enough
Default
I think your best bet would be to find a GOOD local trans rebuilder and have yours rebuilt. Have them do the shift kit and all the other upgrades. I say do this vs buying another one because yours isn't totally shot yet and is a great candidate for a rebuild.
The above is assuming that you've done some troubleshooting - ie the fluid condition is good and it's at the proper level.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
