Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-18-2010, 11:11 AM   #1
ranger450
Year: 1999
Make: ford
Model: ranger
ranger450 is on a distinguished road
Default boosting oil pressure
Is there a way to boost my oil pressure on my 3.0? i remember back in the day you could put a washer under the oil pump. do they make a high volme pump for the 3.0?
ranger450 is offline   Reply With Quote
Old 12-18-2010, 11:14 AM   #2
Hahnsb2
Hahnsb2's Avatar
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
What makes you think you need to boost the oil pressure?
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 12-18-2010, 11:19 AM   #3
ranger450
Year: 1999
Make: ford
Model: ranger
Default
building a new 3.0 and thought it would be a good idea.
Old 12-18-2010, 12:09 PM   #4
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
many people discover that boosting the oil pressure and/or volume puts more strain on the oil pump drive (generally the distributor gear) and causes premature failure of those parts, then you have ZERO oil pressure.
you can achieve this effect on a 2.3 without even needing to take the engine apart,
just put thicker oil than intended in the engine and watch the oil pump drive FAIL....
"Low Oil Pressure" is a symptom of other issues, a professional mechanic who isn't linguistically impared might say "oil control issue"
Excessive bearing clearance that results in low oil pressure is an example of this
an obstructed pickup might be refered to as an oil supply issue...
but a 3.0 likely doesn't need more pressure for any good reason.
If you want to feel good about the pressure buy a 150psi electrical guage
but buy a guage sender for a 75psi guage.
That'll make it read "high" and impress your sensibilities...
Me? I'm generally happy knowing that there IS oil pressure, what that specific pressure is really isn't all that important....
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 12-18-2010, 04:27 PM   #5
ranger450
Year: 1999
Make: ford
Model: ranger
Default
i dont know if that is really true! why would high performance engines have higher pressure and volumes?
Old 12-18-2010, 07:28 PM   #6
Big Jim M
Year: 2002
Make: Ford
Model: Ranger FX-4 level 2
Engine: 4.0
Class: 4x4 Extreme
Used For: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Wink HA!!
Quote:
You can take all that to the BANK!!
Hi-po engines are much LOOSER from the getgo than ours are! The oil in them escapes the oiled bearings lots quicker.
As a side note the WASHER in them old engines went under the bypass spring, NOT under the pump itself! We punched out the drift pin and put a couple of washers between it and the spring.
Big JIm
Big Jim M is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
